4th gen center console into 3rd gen
Old Mar 10, 2010 | 10:21 AM
Brad5117's Avatar
i have a gap in the very front of my 4th gen console on passenger side is this normal ?? also i wanted to put a new shifter **** on my automatic but wasnt sure if i can do that , it is the shifter that has the botton on top and not on the side
Old Mar 10, 2010 | 10:40 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: 4th gen center console into 3rd gen
Are you talking about the gap under the cup holder?
If so, what I did to fix it...I stuffed something under the carpet over there to bump it out. I cant remember what I used. I might have used batting from a previous project. Made it look much nicer over there.
Not sure on your auto ****, but I think some guys remove the button mechanism and just put whatever **** they want on there. You wont have to press the button into shift out of park...which would keep me from doing it.
J.
Like this...
Is that where you meant?
Old Mar 10, 2010 | 12:05 PM
Brad5117's Avatar
yes exactly like that , that actually is exactly like wat im going to do with mine with the radio and stuff
Old Mar 21, 2011 | 06:25 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I'm finally installed my console the other day. I don't know if its the way I made the trans crossmember, but the shifter hits one of the supports. Reverse will be a chore to get into and I move the console when I attempt it. Are there any severe repercussions for cutting that particular support away?
Also, the ebrake latch gets caught up in the rubber surround.. is that normal too?
Ghetto, that's a great idea for hiding the ugly gap by the radio.
Old Mar 21, 2011 | 10:33 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
A little piece of foam from an old torn up seat(Junkyard) stuffed under the carpet will fix that right up....
omega; Sounds like your console needs to move forward, just a bit...
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Casey Meyers
Mar 2, 2016 10:46 AM
DonW
Aug 24, 2015 08:24 PM
Firebird sweden
Aug 16, 2015 05:02 PM
