How to add shoulder strap on rear seats?
Old Jun 17, 2010 | 09:24 AM
DirtDawg57's Avatar
Is there a tread anywhere that tells how to mount the newer rear seat belts with the shoulder strap on a older model. I have an 86 camaro and want to get the newer seat belts but would like to know if its possible to mount it. Thanks!
Old Jun 17, 2010 | 05:32 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: How to add shoulder strap on rear seats?
Never done the swap, but I'd bet you'll need the 89-92 rear belts, the matching rear plastics and you'll probably have to hit the junkyards and cut the belt supports off a donor car.
Old Jun 17, 2010 | 07:17 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
i just removed a set in grey from a '91 formula today. Dante is correct, there is a little platform you would have to weld on. youi could use the existing plastic panels and cut a hole, but it would look better w/ the correct ones as they have a little ridge to mate up to the "tower" plastic. If you are interested in grey, pm me and we'll get you set up w/ the whole shibang.
Old Jul 27, 2010 | 09:08 AM
camaro87jb's Avatar
Car: 87 Iroc z
Transmission: AT
Did you get this to work? I have an 87 i love to convert to rear shoulders.
Old Jul 27, 2010 | 11:32 AM
DirtDawg57's Avatar
No, I would have liked to also but when I heard you have to get into welding and stuff I changed my mind. The people in the back seat are that important. It would be cool though.
Old Jul 27, 2010 | 01:02 PM
camaro87jb's Avatar
Car: 87 Iroc z
Transmission: AT
haha! Well mine would be my twin girls so i would love to know if anyone else has experience in doing this.
Old Jul 27, 2010 | 03:01 PM
DirtDawg57's Avatar
In that case yeah it would definitely be worth it. I was thinking since welding would probably mean taking all the cloth off anyway it would make it a lot easier to get a rear seat out of a 3rd gen that already had the belt holders or a 4th gen.
Old Mar 21, 2011 | 12:08 PM
juansupreme's Avatar
Car: 86 Trans Am
Engine: 350 Roch-4bbl
Axle/Gears: Normal
Hey guys, revving old question.
Wouldn't in be just as good to bolt the plate and shoulder ratchet to the rear plate mount area instead if welding? it's just as strong and I can check twice a year to make sure bolt tite and corrosion free.
Old Mar 22, 2011 | 08:52 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
only problem i see with that besides the fact that those bolts might become loose over time and be no help in an accident for a person in the back seat...
i just drilled the spot welds that held the rear brackets from a junkyard donor car.
you go straight into the wheel well. your just asking for rust when the wheels kick up water up there where those bolt holes are if you drilled to bolt down the brackets.
i'm getting my car and brackets prepped and just going to have a buddy at a shop weld them in. shouldn't cost much at all since most of the work will be done ahead of time.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
MORREALE5
Sep 13, 2015 09:16 PM
z28addict8490
Aug 7, 2015 08:48 PM
