getting exhaust in my car
Old Mar 22, 2010 | 01:24 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
i have an iroc and i think my hatch seal is leaking. if i roll my windows up the exhaust will kill me. is it posible that the rubber is old and smashed and letting the carbon flow into my car. i have new exhaust pipes, i've replaced all of the rubber plugs. i resealed all of the seams. has anyone else had this problem?
Old Mar 22, 2010 | 01:49 PM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Re: getting exhaust in my car
could be the hatch weatherstripping, also make sure that the exhaust is getting out from under the bumper. make sure the exhaust pipe is blowing the exhaust out from under the car and not letting it build up underneith the rear bumper. Not sure if it helps but thats all i can think of.
Old Mar 23, 2010 | 09:15 PM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Are you sure it isnt leaking through your firewall? Maybe the end of one of you headers isnt quite bolted down. Missing gasket?
Or perhaps a rust spot on a floor pan is letting a leak in?
If your exhaust is that thick, I cant see it being the hatch weatherstripping.
Old Mar 24, 2010 | 08:53 AM
aks's Avatar
aks
Car: 92 Z28
Is it possible your floor boards are rotted through because of rust? If you have big rust holes in your floor probably exhaust fumes could get in. Espically if your exhaust system has any leaks in it like mine.
Old Mar 24, 2010 | 01:04 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello mpb74!!
If it was coming in your car through the rear hatch weatherstrip, your weatherstrip would have to be missing........having said that, have you checked the body drain plugs? If they are missing, the exhaust that gets under the car will find its way into the car via these missing plugs!!
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
