Seat belt return springs are weak. Any fixes?
Old Apr 11, 2010 | 07:45 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
My 89 has only about 49.000 miles on it. It's front seat belt return springs are getting quite weak. I'm constantly have to give them a quick tug to snug them back up. Can i adjust/fix this or do i need to just replace?? Thanks guys!!
Don
Old Apr 11, 2010 | 08:19 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Seat belt return springs are weak. Any fixes?
Don
Hello musicfreako!!
You could try a little bit of WD-40 sprayed into the retractor shaft ends once you pull the belt all the way out!! I tried this on some belts that I removed from a junkyard Camaro, and it seemed to work really good!!!
Good luck finding replacements, not really easy to do!!
I have a drivers side belt that needs to be fixed, because the retractor won't retract, so I'm going to try and replace a clock spring on the side of the retractor to see if that fixes it!!
Wish me luck!!
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
MORREALE5
Sep 13, 2015 09:16 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
