4th Gen Cluster HELP!!!
Old Apr 20, 2010 | 02:44 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Ok i was able to get this 99 camaro cluster hooked up. Its working good. everything seems to be ready good. The only issue is that the Brake light, ABS INOP, Service Vehicle lights are coming on. Im not using the 99 BCM. Just wanted to know if there was a way around this. I would really like to get my brake light to work.
Brake Light
ABS INOP
Service Vehicle (Not Service Engine light)
Joey J.
Old Apr 20, 2010 | 03:07 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: 4th Gen Cluster HELP!!!
Since I am pretty sure the 99 uses the serial data line for the gauges, you may have to do like I did for those bulbs. I took the circuit board off the gauges and pulled the small led bulbs for those circuits. You will never need them and they do not interfere with anything when you pull them. But, just to make sure, I heated the solder and after the bulbs were out, I added some more to bridge the connection.
Old Apr 20, 2010 | 03:48 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Thanks bro. I took apart the gauge cluster. Found those LED's. Later tonite im going to take them out and do what you said. I guess thats the only way. guess i will never see my brake light again
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
ChevyZ71
Aug 13, 2015 07:30 AM
