4th gen heater cable
Old Apr 26, 2010 | 04:51 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Before I get started, yes I have searched.
I am trying to figure out how you guys made the 4th gen HVAC control the 3rd gen cable operated hot/cold door. I have been staring at it for days and people reference it in their posts but nobody has actually explained how they did it. I don't want to reinvent the wheel but I may have to if nobody has any pics or suggestions. I am confused as to why people are using an S10 cable just becuase its longer. The 4th gen rotary **** has a completely different movement than the older syle lever action cables. This is the biggest headache I have had so far and I need some help.
Old Apr 28, 2010 | 10:50 AM
1981LT1's Avatar
Engine: LT1; LT1
Re: 4th gen heater cable
Come on guys. Out of everybody that has done this swap, nobody can give me some info?
Old Apr 28, 2010 | 10:57 AM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
I cut the tab that the cable sits on off of the 4th gen box off. I then attached that tab to the pivot point of the third-gen door with a screw. Once I determined what direction the tab needed to sit to get the most travel, I epoxied it on in addition to the screw.
Kevin D.
Old Apr 28, 2010 | 11:06 AM
1981LT1's Avatar
Engine: LT1; LT1
Anyway yiu can snap a pic?
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
cam-mike
Aug 24, 2015 07:23 AM
