Hatch pull down and power window tracks - Whats the best grease?
Old May 4, 2010 | 05:24 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
for the window tracks whats the best grease that doesn't have much drag
that may improve window up ad down speed?
Old May 4, 2010 | 07:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Hatch pull down and power window tracks - Whats the best grease?
I used white lithium, but I'm curious to see what others have used.
Old May 4, 2010 | 09:55 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
White lithium as well... Does wonders... Also fixed the front door of my house! It wouldn't close until i pulled the handle off and sprayed the heck out of everything inside... Closes like new..
Old May 5, 2010 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
+3.
JamesC
Old May 5, 2010 | 08:44 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
yep. lithium FTW.
if you get the spray kind it makes it super easy to lubricate everything with a big sweeping spray motion.
just make sure you get as much of the old grease and dirt and grime off first or it wont make much of a difference.
Old May 5, 2010 | 09:09 AM
JamesC's Avatar
If you haven't seen the link to follow, you might give it a peek for some quieting fixes:
https://www.thirdgen.org/forums/body...servation.html
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
