Rear hatch constantly pulling down
Old May 5, 2010 | 12:14 AM
_87TA_'s Avatar
Car: 1987 Trans am
After multiple batteries losing their charge I'm pretty sure I found out why but do not know how to fix it.
The rear hatch motor operates fine, kinda. it opens fine with switch but it wont close until I press and hold down the switch inside the latch assembly. it goes down then comes back to its norm position. then I'm able to shut it normally and it locking in place. So I think everything is normal now, but i ear a SLIGHT sound of something pulling. No motor noises just a very quiet sound something snug.
So I'm pretty sure it is this. I have disconnected all the wires leading to the hatch motor to prevent more battery drains. Which leaves my hatch open and bouncing around when I drive.
So if anyone knows any remedies for this please inform me.
Thank you.
Old May 5, 2010 | 08:19 AM
WHTrunner's Avatar
Car: 1986 Z28
Re: Rear hatch constantly pulling down
I've heard that a bad motor gear will leave the motor running constantly. Pull your motor assembly out, and take the clear plastic gear housing apart and see if the plastic gear that goes on the motor still has any teeth on it.
It's not hard to take apart. I'm working on mine at the moment. It takes about 15 minutes and a half dozen screws.
Old May 5, 2010 | 08:29 AM
joee5's Avatar
Car: 1986 Z28, 2006 Cadillac Escalade
Engine: 5.0 litre
Mine was doing that as well, the rear plastic interior piece wasnt screwed down properly. I screwed it in place and she stopped humming.
Old May 8, 2010 | 04:19 PM
_87TA_'s Avatar
Car: 1987 Trans am
I will try both of your responses because both I think will make a difference. 1. Because I'm almost positive the gear or something internal is messed up. And 2. All my hatch interior pieces are just hanging there... thanks.
Old May 28, 2010 | 07:51 AM
nethuryn's Avatar
Or you could not waste all that time and just order a new one. Or got to a junk yard or ebay and get a used one.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
