Powering 4th gen seats in 3rd gen??
Old May 7, 2010 | 06:36 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Its been a while since I've had a 3rd gen with 4th gen seats in it but I just got a set of 2000 Camaro seats to go in my 91Z28. My 91 had a power seat (which was gone before I got the car). What solutions has anyone come up with to adapt the factory harness to the new seats? Since I don't have the factory seats, I don't have the 91 seat harness and the 2000 seats didn't come with the body side of the harness.... Is there any other way to power these seats without cutting both ends of the harness off and doing something cheesy like simple wire connectors?
Old May 7, 2010 | 09:32 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Powering 4th gen seats in 3rd gen??
go to the junkyard and get the body wire from a 4th gen car and run that to your fuse panel on an always hot connection.
Or you could go to Radio Shack or some other eletronic supply store and buy a pair of male/female connectors and change the connector on the seats wire and make your body harness wire.
Old May 7, 2010 | 09:42 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You can just pull the factory wire out of a power seat car. It runs all the way back to the power distribution box and has a simple plug on the end. I took one out of my old parts car without any problems.
Old May 7, 2010 | 11:22 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Seats just have 2 wires - power and ground - just run a power wire from an empty fuse slot under the carpet or door sill, and ground the ground wire anywhere.
Old May 8, 2010 | 06:27 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I have the power seat option in my car, so power isn't the problem - I just didn't want to cut my factory end off. Just curious if anyone has ever made an adapter that connected the 3rdgen body connector to the 4th gen seat connector.
Old May 8, 2010 | 08:43 AM
Car: 1992 RS
Engine: Carbed 350
Yeah - I understand that. My point was if you wire it direct, then you can retain the stock wiring without cutting the connector leaving the original connector intact - ie not use the original connector.
Old May 8, 2010 | 09:28 AM
Stephen's Avatar
Car: 87 GTA
Originally Posted by Zepher
go to the junkyard and get the body wire from a 4th gen car and run that to your fuse panel on an always hot connection.........
I sorta agree with this solution the most. In that solution, I would cut & properly splice & solder in the new connector. Or (i like even better) would be to change the seat connector to fit the cars connectors, but finding a 3rd gen connector to salvage might be difficult.
Running new whole new wiring is a waste of having to use new wire & a waste of the old existing wires still being there.
Old May 8, 2010 | 12:54 PM
86sdubzzT/A's Avatar
Car: 1986 T/A
Axle/Gears: Stock
Dont mean to hijack here but im guessing since i have the third gen power seat (connector) i should be able to splice it onto my 4th gen replacement seat.
Thanks for the confirmation...im hoping its this easy.
Old May 10, 2010 | 09:25 AM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
Transmission: 5-Speed
I'm in the process of adding 4th gen seats as well. My car doesn't have factory power installed so I've been looking for mating connectors. So far, I've found this piece that will plug into the 4th gen seat. It's AC Delco p/n PT1157. You can pick one up at rockauto.
http://www.rockauto.com/catalog/moreinfo.php?pk=82410
Old May 10, 2010 | 11:13 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
If you need fbody parts, you need to find an fbody junker. My local shop I use is JJ's Automotive. Call 724-547-2959 ask for Brian. They have a bunch of cars laying around they should have power seat wiring and connectors
Old Jun 9, 2010 | 08:38 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
Funny because my fourth gen seats have 6 wires. WTF do i do with that?
Old Jun 9, 2010 | 08:57 PM
Car: 1992 RS
Engine: Carbed 350
Yikes! Ummmm, I don't know! Tie two sets of three together maybe?
You must have some fancy seats there!
Old Jun 9, 2010 | 09:02 PM
Car: 91 RS T-top
Ha ha not sure. They came out of a 99 trans am. Ive had them for a while and just now decided to install them. But its adjusted to far forward and that does not work well im 6'2" i need leg room.
Old Jun 10, 2010 | 07:47 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Just got the harness from the same guy I got my seats from. Wired it up and it looks factory.
Old Jun 12, 2010 | 10:01 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Is this still an issue 2 weeks later?
From the picture, that six-wire connector looks to be what
activates the three directional motors. Where is the switch panel?
I suspect the connector in the picture is intended to connect to
a switch panel, and that component is where the constant power
& ground connections are included.
Good luck,
kk
Frozer!!!
Jan 19, 2024 04:55 PM
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
