anxious airbag!
Old May 16, 2010 | 06:41 AM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
anxious airbag!
Hey all
Perhaps being a bit paranoid but my stock 20 year old steeringwheel airbag is playing on my mind alittle.
I mean as much as I love these cars, mechanically and electrically, they perhaps aren't the best built.
Has anyone ever heard of an airbag deploying without being at all provoked?
I am contemplating decommissioning it- is there a particular method to do this without tripping any codes or causing the airbag warning light to stay on?
Thoughts welcome
Old May 16, 2010 | 02:27 PM
92-Formula's Avatar
Re: anxious airbag!
If you disconnect the airbag, the "INFL. REST" (inflation restraint) light will remain lit. An easy fix is to just pull the gauge cluster and remove the bulb.
However, if the only reason you want to remove it is because you're worried its going to go off for no reason... i wouldn't bother.
Old May 17, 2010 | 01:37 AM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
Re: anxious airbag!
Hi Welcome to TGO Neighbor from across the pond!
On TGO Homepage there is a variety of articles dedicated to common Third gen problems, Here is the link to the airbag removal. Be careful though, however unlikely it could go off.
https://www.thirdgen.org/airbag
Old May 18, 2010 | 04:34 PM
GTA1990's Avatar
Car: 1991 Trans Am
Re: anxious airbag!
Thanks guys - sorry I didn't get a notification that someone had replied
Yeah should be fine - car does make some rather strange noises and electrical inconsistencies make me think twice abou the airbag
Cheers for the welcome and link Jack!
Yep easiest way seems to be pulling the fuse and light
Thanks guys>>
Old May 31, 2010 | 07:30 PM
Werewolf SS's Avatar
Car: 1989 Camaro RS
Engine: V6 - LS Swap Incoming
Transmission: 700R4 - T56 Mag F Incoming
Re: anxious airbag!
I was in the same boat as you but even more so since my 90 Camaro is the first year they were installed and as these are the first generation airbags and not the more relaible and secure 2nd gen airbags I was taking no chances and removed the airbag and replaced the steering wheel.
1st generation airbags were notorious for killing more people then they saved as the airbag would deploy with maximum force. For someone who weighs less then average or weighs more they could be hurt by the force of the airbag instead of being cushioned and for more heavy people the airbag would not cushion at all.
2nd generation airbags are much more safe as they incorparate a sensor in the seat that determines the weigh of the occupant and adjust the deployment pressure for the airbag based on the weigh of the occupant and the speed of the vechile and location of the crash and it's impact force....much more safe.
Like the others said above to keep the steering wheel just pull the fuse and the inf rst light bulb.
Eric-86sc
Feb 25, 2016 09:02 PM
1992Z28!
Nov 19, 2015 07:33 AM
tealman92
Sep 28, 2015 01:43 PM
tattmann
Sep 27, 2015 05:20 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
