dakota digital guages???
Old May 17, 2010 | 10:42 PM
Military Clone's Avatar
Car: 1984 Berlinetta
Axle/Gears: 3.08
Has anyone put these gauges in a 84 berlinetta. What do I have to do install these. What i mean is it easy ( cut some wires and plug them in there spot).
http://www.dakotadigital.com/index.cfm?ptype=results_w&mode=zoomℑ=prd_zm_168.gif
Old May 17, 2010 | 11:23 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: dakota digital guages???
If your Berli has the analog dash, it's not hard to install one of these, I'm not familiar with the stock digital dash harness. I had them make one for my '92 RS several years ago, which cost quite a bit more. Basically, just use T-taps to splice into the stock harness behind the gauge cluster (this leaves the stock harness intact) and run those to the Dakota Digital CPU which needs to be mounted under dash somewhere close. A ribbon cable connects the cluster to the CPU. The hard part is figuring out which signal wire activates what light or gauge.
Here's a picture of mine taken during a dyno pull, 102mph is all the V6 could get on those rollers.
Old May 18, 2010 | 08:31 AM
Axle/Gears: 3.08
Could you set the mileage to say what you car has on it now.
Old May 18, 2010 | 09:47 PM
Al Hasse's Avatar
All you have to do is request it when you order them. I ordered mine with 177K.
sheachopper
Jul 31, 2019 11:27 AM
Eric-86sc
Sep 28, 2015 11:37 AM
