Swapping 90-92 140mph speedometer; questions
Old Jun 3, 2010 | 06:38 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I just bought a 1992 B4C 140mph speedo for my 91Z28 to replace the 110 speedo.
IIRC, Its just a simple bolt in thing, correct? Swap 'em and that it? How about swapping odometer internals? My car has 159k, whereas the new guages have 200k+ on 'em; Can I swap the odometer units in the cluster?
Any help would be awesome!
Old Jun 3, 2010 | 05:42 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Swapping 90-92 140mph speedometer; questions
i'm a little confused . your sig. says 91Z28 , you should already have a 140 speedo . ( your 91Z28 may be a poor little 91R/S ) anyway it should be a plug & play after you swap out speed sensor on transmission . good luck .
Old Jun 3, 2010 | 05:54 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Its a 305 so it got the 110 speedo.
Old Jun 3, 2010 | 06:03 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
No need to swap out the speed sensor on the transmission. You may have to swap the printed circuit board behind the tach though. I had to on mine, but I have a 305 TBI RS, so you may not have to. There is a thread about odometer fix, shows how to take it apart, from there you should be able to swap em out, do a search for the thread.
Old Jun 3, 2010 | 06:23 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
The 305TPI 91-92 Z28's got the 110 unless they were 1LE/B4C cars... IIRC.
Mine is a just a run of the mill 91 Z28. (No RS/Z28 clones here)
Any idea where to find said link? I did a search but came up with nothing except swapping odometers on the 82-89 gauges.
Old Jun 3, 2010 | 08:54 PM
UNCLE TOM's Avatar
sorry i may be wrong . i said i may be . i just bought a 91Z28 parts car . TPI , T-5 , T tops , A/C , 140mph speedo . it's not a 1le or b4c , since it's a parts car , trashed & will never see the road again . the VIN # is 1G1FP23F5ML108032 . is it one that slipped through the holes ? i really don't know . never too old to learn . good luck .
Old Jun 4, 2010 | 07:15 AM
Drew's Avatar
The 91-92 Z28 is just like earlier Z28's, in that GM sold some with less/more performance options. They could be had with the F41 suspension, 235 tires, the 110mph speedometer, single cat, and 2.73 gears. Or they could be had with FE2 suspension, 245/50 tires, 140mph speedometer, dual cats, etc. A 305TPI/5spd car with G92 would have the 140mph speedometer.
Old Jun 4, 2010 | 08:57 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
If you are swapping instrument clusters between 91-92 models its simple plug and play. The clusters are electronic so there is NO need to look for, let alone swap out the speed sensor.
To disassemble the instrument cluster, remove the needles and peel off the overlays. Here is where you will be able to access the light bulbs. You should also see tiny screws that you can take out to get to the odometer. Once disconnected you can change the odometer wheels to reflect the mileage you want and just put everything back together.
WARNING! Be VERY careful when removing the cluster needles and overlays. the needles should pull out with gentle but firm pressure. Take your time peeling off the overlays because they can tear or crease. Be EXTREMELY careful if you have to remove the little electrical windings behind the needles (I don't think you will need to unless you find out one of the guages is not working). There are tiny wires there and if they break, you will have to get it replaced by a speedo shop.
It's not difficult to do. Just take your time and pay close attention to how all the parts go back on. Good Luck
Old Jun 4, 2010 | 10:23 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I can't speak specifically about Camaros but I swapped my 1987 Trans Ams 85MPH cluster for a 140MPH speedo from another 1987 car. All I did was swap the clusters and I ran the car up past 90MPH to make sure it worked. I also had another vehicle pace me to make sure my readings were accurate and they were.
Its an easy swap.
Old Jun 8, 2010 | 01:36 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
i just did this same swap last week. i have a 91 305 z28 with the 110 gauges but just swapped the 145 gauges in. it is as simple as bolting it in no modifications required. good luck
Old Jun 8, 2010 | 04:35 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Its a G92 thing. If the car got g92 then it got the 140 speedo.
Old Jun 8, 2010 | 05:03 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Thats what I was hoping to hear. I'm hoping to get them either late this week or early-mid next week and I'll swap 'em in whatever day they get here...
'Course that's all dependent on how quickly I can swap my odometer into it! The donor car was a B4C car so its got over 200k on it and mine only has around 159k.
Old Jun 12, 2010 | 01:04 AM
hardon85's Avatar
did you get this on ebay I think I was bidding on the exact same cluster
Old Jun 12, 2010 | 04:27 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Probably - The ones from a B4C/1LE Texas DPS car.... They just showed up at my house today... too bad I won't be home until tomorrow night.
Old Jun 13, 2010 | 07:36 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I got home today and attempted to remove the odometer from the 140 cluster - I got the needle off and the assembly out of the cluster - BUT -The actual overlay tore. Nothing I could do; it was just super brittle. So; Now I'm on the hunt for gauge overlays. Does anyone know if GM still sells just the overlay sticker part?
If not, who makes overlay kits that will REPLACE the stock overlay?
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
355sbcTPI
Aug 19, 2015 04:38 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
