Steering Column exchange
Old Jul 20, 2010 | 01:15 PM
suks2bu37's Avatar
Car: 1983 Pontiac Trans Am Daytona Pace
Engine: 305 Crossfire injected
Transmission: 700R4 with shift kit
I am needing a steering column for my 1983 Trans Am Daytona Pace Car. Someone stole the car and destroyed the column. Now my windshield wipers work sometimes and not others (like in the rain). The headlights won't go to bright and the top of the shaft where the steering wheel mounts is mushroomed. What years are compatable? The local salvage yards say 1982 and 1983 only due to the pulse wipers and cruise. Any help?
suks2bu37
Old Jul 25, 2010 | 09:56 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Re: Steering Column exchange
Well, i just replaced my Steering Column in my 1982 Sport Coupe (Camaro) with one from a 1984 Camaro. Everything seemed to go well EXCEPT for the Wipers. the wipers wouldn't work. The plugs were the same and everything. I thought the switch might be bad but i didn't look forward to taking that column apart again. I got under there with a Test light and clipped the ground onto the column mount. I touched each wire with the light and saw that the wipers actually came on!! Of course, the light lit too, but i looked a little closer. Where the Connectors were the same, the wires were in different positions. I looked for an OEM kit to make the installation look good, but after going to the dealership and looking online i was unable to find a solution. My Final solution: I clipped off the connector from the Column side (At least the Harness would be intact). and crimped all the wires to the connector of the old Column in the proper positions. The result was that the wipers work, but only on High. I need to work on it some more to make it better. I hope this helped a bit. If you're ambitious, you could go into this with your eyes open and wire the old switch into your new column right off the bat. that way you wouldn't have the same problem. i'm sure that the old switch would fit on the new column. If you're unsure about ignition, you could also swap that over. The Column it's self is mechanically Similar from what i saw. They just like to switch the wiring around for some reason.
Ed1LE
Sep 30, 2018 09:14 AM
gixxer92
May 18, 2017 11:20 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
