Headlight Knob
Old Jul 23, 2010 | 12:13 PM
TCuevas92's Avatar
Headlight ****
Hey guys I have a little problem.. i had to replace the headlight switch in my camaro and i got most of it put back together, but the **** wont click into place into the switch.It slides in but just wont lock into place.. i had it in before i got the switch in place and it clicked in then but now it wont. Ive benn at it for a few hours now.. any ideas?
Old Jul 23, 2010 | 05:20 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Headlight ****
Don't know if you can still get to the switch, but sometimes when I pushed the release button, it wouldn't release, but when I turned the dimmer **** back and forth a few times it would eventually work, so maybe try doing that and it will go in? You have to use a little bit of force to get it to click in, but not a lot. Did you try putting it back in and taking it out when you had the switch out? You may end up having to do that if nothing else works. Good luck!
Old Jul 24, 2010 | 01:05 AM
TCuevas92's Avatar
Re: Headlight ****
Well I had the **** in the switch before I installed the switch in place so it should go in now .... I tried pressin the release button but I guess I'll give it another go tomorrow. Thanks
Night rider327
Feb 25, 2016 09:50 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
