Stripped bolt holes in dash
Car: 85 Trans AM
Engine: Chevy 355
The holes in my dash that hold the cluster/gauge cover are stripped,im sure plenty of other people had this problem.
What did you do to fix it?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Stripped bolt holes in dash
I believe they have clips in there that the screws go into - maybe you can replace them. I think they look like:
http://www.dormanproducts.com/catalo...ec20_Part1.pdf
Called U-type Spped Nuts - Scroll down and look at like part number 700-542
Most auto parts stores carry these in the HELP! section in a box that has various sizes.
Car: 85 Trans AM
Engine: Chevy 355
Thanks for the quick reply!
For some reason I thought it was just plastic holes in the dash where the screw/bolt goes. I will go back in the garage and look again.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
they are plastic posts, they strip. Use a slightly larger screw, thats about all you can do. unless you can fill the hole with epoxy, and drill it back out to the right size
Car: 85 Trans AM
Engine: Chevy 355
Car: 1989 IROC
I would use J-B Weld or a slow cure epoxy. Just remember the faster cure time epoxy will get brittle over time faster than slow cure. I have not seen J-B Weld get brittle.
Car: 85 Trans AM
Engine: Chevy 355
Car: 1989 IROC
I lean towards the cold weld due to you will be using it to dill and put screws in. That stuff bonds better and almost seams better than original, once you're done.
I would get something to test it on and see how it works. You will be impressed. That is if you mixed it correctly. Also make sure you clean and prep the whole to be fixed. Any dirt and it will not bond properly.
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Get a Set of Helicoils. Drill out the hole to the size called for in the kit for the Thread size you need. Use the provided Tap on the hole. Be Careful since the hole is PLASTIC, not metal. Once you have drilled and tapped a new bigger hole, screw the Helicoil into the hole and you will have a Stronger more professional looking repair than OEM. You may want to set the Helicoil with Thread Locker or MAYBE Super glue, but only AFTER you've installed it. If i were to use the Super Glue (I never have tried it) I would use a VERY small amount right at the top of the repair. you wouldn't want to get it on your nice new threads. The purpose is only to keep the Helicoil from backing out. Just make sure that if you go that route, you apply the glue AFTER you have completely installed the Helicoil.
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
The epoxy fix is the best repair! Larger screws don't look stock and other fixes require making the damage worse! Just put some epoxy on a toothpick and coat the inside of the oversized screw hole. Make sure it cures 24 hours before you put the screw in.
The Helicoil Repair would allow him to use the stock screws. The only reason he would have to drill the hole larger would be to insert the Metal Helicoil. The Inside of the Helicoil would have his old thread size. Trust me, The Epoxy repair would look Horrible and wouldn't be as Strong. I've been a Machinist in the Navy for 4 years and then the army for 12 years. Helicoils would make a nice repair. Again STOCK SIZE screws.
For all of you that don't know what i'm talking about, here's the procedure:
http://www.youtube.com/watch?v=RFYa6sjhh_E
Harbor Freight or Sears would have what you are looking for.
I hereby Apologize to Wdigitog. Since i have to replace my cluster as well, i went outside to remove it. I noticed that all the screws involved were self tapping or sheet metal type. There are no Helicoils for this application. It seems to me that the only course of action would be epoxy. I'm sorry to have misled you jprix. Perhaps in another situation, Helicoils would be a neat clean repair, but not in this one. Next time perhaps i should do some more research on exactly what the application is. Again, i'm sorry to anyone i've misled or offended.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
