Finished my 4th gen seat swap
Old Aug 12, 2010 | 02:28 PM
bizkit642's Avatar
Car: 92 Camaro
Engine: 383 stroker
Pretty happy with how it turned out. Definitely an easy mod to spruce up the inside.
Old Aug 12, 2010 | 02:45 PM
joee5's Avatar
Car: 1986 Z28, 2006 Cadillac Escalade
Engine: 5.0 litre
Re: Finished my 4th gen seat swap
Them some nice seats and look as if they came with and were made especially for the car. Did you purchase them in that condition or did you get them redone?
Old Aug 12, 2010 | 03:03 PM
bizkit642's Avatar
Car: 92 Camaro
Engine: 383 stroker
I found them on a local f-body forum. They came out of a 96 z-28 that the owner had them redone.
Old Aug 12, 2010 | 03:23 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
nice!
Old Mar 25, 2011 | 09:41 PM
c9qjyq3's Avatar
Car: 92 Camaro Rs
Engine: CHEVY 350
Axle/Gears: open 2.73
Did the seats bolt up directly?
Old Mar 25, 2011 | 09:49 PM
1991z28camaro's Avatar
Car: 1992 RS Convertible
Engine: 5.0 L 305 TBI
Bolt straight up with no worries.
Old Mar 27, 2011 | 12:36 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
what year steering wheel do you have? is the airbag operational?
Old Mar 28, 2011 | 02:07 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Thats a '90-'92 steering wheel.
I think I would've recovered the rear speaker (Sail) panels in black, but overall, I really like the look!
Old Apr 2, 2011 | 11:04 PM
GLENNDALE83's Avatar
Car: 1988 CHEVY CAMARO
Transmission: AUTO
i was thinking about getting the 90-92 steering wheel, does it fit with out mods or adapters, is there anything i might need to know before getting one?
Old Apr 2, 2011 | 11:25 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
do the 4th gens have folding rear seats too?
Old Apr 3, 2011 | 10:07 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
yes
Old Apr 3, 2011 | 03:37 PM
TheGr8erG00d's Avatar
Very nice, I love that look. Black armrests would pop and look pretty sharp too, maybe the sail panels, not sure. But as is, beautiful!
Old Apr 3, 2011 | 04:29 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Yes, but all 4th gens has 1-piece folding backs, unlike some of the 3rd gen split seat backs.
Old Apr 4, 2011 | 12:07 PM
fastgascar's Avatar
Sounds like this was a direct bolt in, so am I safe to presume that if I find the drivers side electical chassis for the seat from a Gen4 Camaro it will bolt in directly into my 88 IROC? Are the electrical connections the same?
Old Apr 4, 2011 | 01:14 PM
Car: GTA
Bolt-in yes. Plug-in no. The wires require cutting & splicing of the wires.
Old Apr 5, 2011 | 10:52 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
yeah and its REALLY hard...
power.. and a ground....
Old Apr 5, 2011 | 11:16 PM
Car: GTA
Sarcastic or just plain rude? I can't decide which one you were being there. Little bit of both, I'd say. I stated it clearly & you posted what???? Try saying something productive. Your Post was of zero help here.
If you think it is just 2 wires...You better have a handful of fuses on hand when you start doing this.
Old Apr 6, 2011 | 01:59 AM
haulinthemail's Avatar
Looks good, I'm swapping the seats from my 93Z into my 89 IROCZ drop. The seatbelt guides on the back seat wont fit, so they're coming off( who needs those?) What size bolts did you use to secure the back bottoms?
As for the power, the wires are the same but the connector is different, one is vertical(89 I think) and the other is horizontal. 2 min fix max. they fit nice though!
Old Apr 6, 2011 | 06:59 AM
fastgascar's Avatar
I was able to take the 94 electric driver side seat chassis and simply plug the same three plugs used from the 88 control panel into the motors and everything worked as designed.
Old Apr 6, 2011 | 09:44 AM
aqualordx93's Avatar
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
looks amazing! are those your stock seat belts? or 4th gen seat belts?
Frozer!!!
Jan 19, 2024 04:55 PM
AkDrifted
Aug 17, 2015 07:45 PM
sreZ28
Aug 14, 2015 07:48 PM
armybyrd
Aug 10, 2015 09:23 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
