Power Door Locks....?? Not locking.
Old Aug 17, 2010 | 06:36 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
My car has power locks. When i push the lock button it does not pull the lock into the lock position. If I lock it by hand, the unlock button will unlock it but i have to push it about 4 times. Are the acuators on the locks worn out or is there an easy way to replace them??
Old Aug 17, 2010 | 07:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Power Door Locks....?? Not locking.
The common culprit is 20+ years of dirt/grime. Often a thorough cleaning with something like WD-40, then a shot or two of white grease will eliminate the problem. While you're in the door, you might consider some of the following ideas:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Aug 18, 2010 | 06:54 AM
techno101's Avatar
Car: 1989 Camaro RS
sweet I'll check that out!!
Old Aug 21, 2010 | 09:33 AM
techno101's Avatar
Car: 1989 Camaro RS
cleaned it all up with wd-40 and then lubed it up good with white lithium grease. Everything work like new now!! Thanks!!
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
