Rear seat back interchangability
Old Aug 17, 2010 | 09:38 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I'm pretty sure the rear seats for Firebirds and Camaros are interchangable throughout the entire thirdgen years. Am I correct? The reason I ask, is that I have wanted some of those split rear seat backs. Today I was at a junkyard that had an '84 Firebird and an '85 Camaro that both had split rear seat backs. Just wanted to make sure they would fit in my '91 GTA before I went and removed them.
Old Aug 18, 2010 | 12:18 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Rear seat back interchangability
You can put the solid back seat in a split back car, but you can't put the split backs in a solid rear car. There are welded in brackets that hold the split back seats in the center at the tranny tunnel hump.
Old Aug 18, 2010 | 02:52 PM
Is it possible to bolt that middle bracket in place? Or to fab a new one to weld/bolt in?
Old Aug 18, 2010 | 03:06 PM
Stephen's Avatar
Car: 87 GTA
The split rear center brackets are spot welded in, but nothing says they can't be cut them out & put in a solid rear seat car.
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
You could remove the bracket from the donor car and have it welded into yours. I grabbed one but had to use a chisel since they don't allow cutting tools, but it's just a few spot welds. The trick would be locating where the bracket needs to go on your car. Could try measuring it's location before removing it.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
z28addict8490
Aug 7, 2015 08:48 PM
