Removing Door panel/ fixing handle
Car: 1988 Firebird Formula
Axle/Gears: 3.42 Posi
Hey everybody,
The other night the exterior door handle on my drivers door stopped working so I am assuming something is broke/unhooked on the inside of the door. Two questions..I am going to remove the door panel to take a closer look I have never removed a door panel on a third gen before is it just the basic clips going into the door setup?...Second once I get inside the door is the door handle mechanism for the exterior handle easily accessible to work on? Or is it blocked off by something in the way?
Thanks for any help
Thanks for any help
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Removing Door panel/ fixing handle
Hey everybody,
Thanks for any help
Thanks for any help
https://www.thirdgen.org/forums/body...servation.html
JamesC
Hey thanks ill search around some more on here and that thread just might help out also
Car: 1991 RS Camaro
Engine: 400 Smallblock
Taking the door panel off is pretty straight forward but you'll need a torx screw driver for those trim screws. The rods that connect the handle to the latch are not hard to see but you do have to kinda of twist your arm up in there.
Ok im gonna tear it apart tommorow afternoon to see what is going on in there..im guessing its most likely gonna be that my clip holding the rod to the exterior handle is broke/fell off..and if its broke im kinda screwed since i dont have a spare one laying around..
Car: 85 Z28
The Help section of most parts stores carries a set of assorted lock rod clips for a few bucks. I'm pretty sure that one or two will fit our cars.
Sounds good ill check that out if the clip is broke ill let you know how it goes
