Rust Removal On IROC Horn Button
Old Sep 3, 2010 | 05:27 PM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
Snagged a horn button that looks perfect on the front, but the back is rusty.
1) What should I use to remove the rust?
2) Once removed, can it be coated to prevent future rust?
3) Will my steering wheel, which is in great shape, start rusting if I can't remove all of the rust?
Old Sep 6, 2010 | 08:39 AM
Re: Rust Removal On IROC Horn Button
Thanks anyway.
Old Sep 7, 2010 | 08:42 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
so it's just the horn button? Why worry about it at all? You can't see it once it's installed. They all develop a little bit of surface rust over time, but it's nothing to be concerned with. If yours has a bit more than most, just grab a used one, or sand it with some sandpaper until you're satisfied.
Frozer!!!
Jan 19, 2024 04:55 PM
smooth
Aug 18, 2015 06:34 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
3rdgenparts
Aug 8, 2015 07:09 PM
