repairing crack in dash
Old Sep 14, 2010 | 10:10 AM
Stratocaster25's Avatar
Car: 1992 Z28
Engine: LB9 305
My 1992 Z28 has a small crack on the passenger side of the dash. It's probably a little less than an inch long and if you push down on it, it seals up pretty much perfect. Is there an easy way to fix a crack such as this? Here's a picture of the crack:
Old Sep 14, 2010 | 02:25 PM
Drew's Avatar
Re: repairing crack in dash
I'd be tempted to use a couple drops of super glue. The hard part is getting it in the crack, and not on the surface that will be exposed after it's set up.
Old Sep 15, 2010 | 06:33 AM
Car: 1992 Z28
Engine: LB9 305
I was thinking of that as well. I just have to figure out some way to get it in that small area without doing what you said or making the crack any bigger.
Old Sep 17, 2010 | 12:49 AM
hardon85's Avatar
how far can you pull the loose piece up? If you can get it up a little ways I would think you could get some super glue under there. but I wouldn't expect to much I bet by next year it will be coming back up again, but hey it's worth a shot.
Old Sep 17, 2010 | 08:53 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
If you can get a hold of one u could always use a wide needle syringe .. by buddy uses them to touch up paint on cars.....I had a similar crack and I used a little super glue then covered it with some vinyl repair stuff from autozone... after that you couldn't even notice it
Old Sep 17, 2010 | 09:33 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
If that doesn't work you could try drilling out crack, fill, and respray entire pad.
https://www.thirdgen.org/forums/auto...-dash-pad.html
F.I. 57 Belair
Aug 23, 2021 01:09 AM
MantyZ28
Nov 8, 2015 06:54 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Stryker412
Sep 7, 2015 09:11 AM
Ian Irvine
Sep 4, 2015 08:08 AM
