difficulty putting gauge cluster back in...
Old Sep 20, 2010 | 08:17 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Removed it easily enough once the speedo was disconnected, but I am having difficulty getting the gauge cluster back in, I got it over the part of the steering wheel that tilts, but I can't quite get it low enough to slide it the rest of the way into its little cubby hole, could use a tip =/
Old Sep 20, 2010 | 08:27 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: difficulty putting gauge cluster back in...
Try droppingthe steering shaft. look under the dash there are two bolts ( i think 1/2 inch) and loosen them up alittle to allow the shaft to drop alittle, you should be able to get them in now.
Old Sep 20, 2010 | 08:46 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Sometimes you can tilt the assembly with the top forward and it will slip in/out. Sometimes it won't, but if you pulled it (at the same point of disassembly) it should go back in.
If it becomes too frustrating, dropping the steering shaft becomes relatively easier.
Old Sep 20, 2010 | 03:30 PM
Engine: 3.8, 3.4
I did, made all the difference,lol. Just doesn't make sense though, I wouldn't say getting it out was easy, but it wasn't impossible..and I didn't touch the steering shaft nuts either.
Old Sep 20, 2010 | 08:25 PM
Scorpner's Avatar
Engine: V6, V8
Sounds about right. I get stubborn sometimes and had one that just wouldn't go back in without dropping it no matter what I tried.
Old Sep 22, 2010 | 12:52 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I had to tilt the wheel all the way down and then remove the tilt lever to make it easier
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
justin57
Aug 20, 2015 07:05 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
