Where did you guys hide switches????
Old Sep 24, 2010 | 11:00 AM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
I am gonna have to find a spot to put a switch, I'm putting nitrous on the car and don't want it to be seen. Any ideas? I was thinking about making a plate for the inside of the center and putting them in that.
Old Sep 24, 2010 | 11:41 AM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
Re: Where did you guys hide switches????
well if we told you it wouldnt be a secret locaton
Old Sep 24, 2010 | 11:44 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I've seen pics of guys who put a rocker switch panel in the ashtray. looked AWESOME
Old Sep 24, 2010 | 11:46 AM
spade's Avatar
I've also seen people mount them on their seat.. Column, ashtray, under the dash, etc
Old Sep 24, 2010 | 11:49 AM
58mark's Avatar
https://www.thirdgen.org/forums/post...45-post36.html
Old Sep 24, 2010 | 02:28 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Can you spot the switches on my car?
Old Sep 24, 2010 | 02:34 PM
Axle/Gears: G92
Above the a/c controls ? Btw I have the same steering wheel.
Old Sep 24, 2010 | 02:56 PM
Zepher's Avatar
nope, look to the left of the steering wheel
Old Sep 24, 2010 | 03:35 PM
Axle/Gears: G92
Under the dash. I see little lights lol
Old Sep 24, 2010 | 03:47 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
I had a rocker switch under the section of the dash where the headlight switch is. You could NOT see it from outside the car, or even when sitting down (unless you saw the faint red glow on my leg when it was on).
Old Sep 24, 2010 | 03:54 PM
da.slyboy's Avatar
Car: 84 frankenstein Z28
Not really that secret, but I used the empty slot where the flashlight went (I have the overhead console).
Old Sep 24, 2010 | 04:23 PM
grassyflats's Avatar
how 'bout a footswitch way up under the dash on the firewall
...the ashtray is really cool like in Neils old 427
https://www.thirdgen.org/forums/cama...ro-iroc-z.html
Old Sep 24, 2010 | 04:54 PM
Axle/Gears: G92
I really like the ashtray posted above.
thanks for the idea.
that's pretty cool.
foot switch could get hit on accident though..
Old Sep 24, 2010 | 06:25 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Here are mine. Fuel pump and fans.
Old Sep 25, 2010 | 02:06 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
In plain sight!
Old Sep 25, 2010 | 02:14 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
That footswitch idea is really cool. Make it a little button under the accelerator pedal that way it only is used when you floor it. Which of course is the only time you would use you never see some body pushing the accelerator halfway and using nitrous.
Old Sep 25, 2010 | 05:16 PM
yeah...right
Old Sep 26, 2010 | 06:52 PM
jtsherrod's Avatar
yea i have that overhead console.. i cut off the leather bag thing and just mounted the switches for all to see lol
Old Sep 26, 2010 | 07:21 PM
chevelle600's Avatar
Car: '87 IROC-Z/28
Engine: 357 HSR
Axle/Gears: 3:73 w/Eaton Posi
ive got my roll control switch and light mounted on the side of the console pointing towards my ebrake handle.
Old Sep 26, 2010 | 07:28 PM
ls1fiend's Avatar
Car: 1985 z28, 1994 Sierra
Engine: 350, 350
Transmission: T-5, 4L60E
Lol my dad used to do the footswitch under the accelerator setup for his nitrous. He used to terrorize hallsville, tx in a 69 c10 that would lift the front left tire off the ground.
Old Sep 26, 2010 | 07:31 PM
of course Bond James Bond had his ejector seat switch
hidden under a flip up door inside the end of the shifter
Old Oct 5, 2010 | 12:54 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
i use my hatch switch no one can tell you have nos like that
Old Oct 5, 2010 | 01:47 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
That's true. You could even get factory switches for the blanking panel locations and fool the average joe.
Old Oct 5, 2010 | 02:26 PM
Drew's Avatar
Hidden didn't really play into my setup. I wanted it to function. The big red rocker switch is the Nitrous arming switch. The two toggles were for killing the remote turn on for the amps, and a control for the lighting under the dash. The momentary contact switch on the shifter is wired in series with the WOT switch.
Old Oct 5, 2010 | 08:30 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
mounted a couple black switches in the trim panel to the left of the steering wheel in my '84 TA. kind of hard to see in this picture, but they almost look stock.
[IMG]https://www.thirdgen.org/forums/Name:  P3180148.jpg
Size:  52.2 KBName:  P3180148.jpg
Old Oct 5, 2010 | 09:06 PM
I think it would be cool if your power doors dont work then make those switches for whatever you want. I know pressing the button will be akward but it is an idea. Here is another crazy one on my car the trip reset button resets the miles but the miles dont move anyway ( heard it broken clips ) maybe button behind gauges and make the trip reset button be your nitro or whatever.
Old Oct 6, 2010 | 08:37 AM
Pocket's Avatar
Car: 91 Trans Am
Ive since removed them
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
86IROC112
Aug 17, 2015 02:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
matthew911
Aug 12, 2015 09:38 AM
