armrest upper bolt not biting
Old Oct 4, 2010 | 11:25 AM
gta90's Avatar
Car: 1990 GTA (T-Top)
Engine: 305 TPI (LB9) / 115k miles
Transmission: 4L60 (MD8 non-E)
Axle/Gears: 2.73 (GU2) 28 spline POSI (G80)
I can't get the upper armrest bolt to fasten properly to the door panel. It seems to bite a little, but after a few minutes on the road the bolt wobbles loose until finally falling out. I'm guessing the hole in the door panel is too wide now due to wear/stress over the years. Does anyone have a fix for this? I'm guessing a wider bolt is needed.
Old Oct 4, 2010 | 01:30 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: armrest upper bolt not biting
I have a similar issue with the passenger armrest. I think the best remedy is to just go to the junkyard, drill out the rivets on a bracket and bring it home to replace the bad one...
Old Oct 4, 2010 | 01:34 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
sounds like the nutcage is toast. junkyard time.
Old Oct 4, 2010 | 01:46 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
On my cars, the plate that the screw... Er.. Screws into is just sheet metal. I would take a pair of needle nose vice grips and get one jaw behind it and then smash the hole back flat. That should close up the hole and make it small enough that your screw should fit again. I own a MIG welder, so if the before mentioned idea didnt work, I would drop a few sparks in the hole. That would do it, I think. Hope this helps!
Old Oct 4, 2010 | 03:13 PM
gta90's Avatar
Yeah I didn't think there was a nut on the door panel, at least for the upper bolt. Instead its a slit in the sheet metal. I guess this could be a difference with GTAs. I'll use the needlenose method and see about getting the gap closed smaller. If that don't work I'll try a slightly fatter bolt. If that don't work I'm going to bust out my blind rivet gun and set a threaded anchor in the door panel.
Old Oct 4, 2010 | 03:37 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I too was going to suggest the pliers and flattening the hole, or a larger screw - they are well hidden up in the armrest, no one would ever know exactly what type of screw was in there. Another option would be a small piece of aluminum or metal riveted over (or under) the bracket and then drill a new hole in that for the OEM screw to bite into.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
