Temp. Gauge Issue
Old Oct 14, 2010 | 12:03 PM
86CamaroNJ's Avatar
Car: 1986 Camaro Sport
Engine: 305 Carb
Transmission: 700r4 with mild shift kit
Axle/Gears: stock, looking to upgrade to 4.11
Temp. Gauge Issue
All my gauges are stock and upon purchasing the car the temp gauge was broken (stuck in the full down position). I purchased one in working condition from my buddy, and after installing it, it bounces straight up after turning the ignition to the on position, and it gets stuck there. I put a piece of cardboard there and then it got stuck at the bottom, I just want to know what the hell is going on
Old Oct 14, 2010 | 04:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Temp. Gauge Issue
Check the sender - driver head between #1 & #3 plugs.
Old Oct 15, 2010 | 10:46 AM
Midwest Muscle's Avatar
I don't understand the cardboard comment, but what you describe is explainable by a sender wire that's grounded when it shouldn't be. If the wire running to the sender unit between Cyl 1 & 3 is grounded (zero resistance), the Temp gauge will go full pop when you turn the key to On.
Old Oct 15, 2010 | 10:56 AM
DacMan's Avatar
I bought a new sending unit and wired it in and my temp gauge still doesn't work, i know that the ground wire can just be grounded to the frame, and it it, so should I run the other wire that runs to the gauge and make sure that it is in good condition?
Old Oct 18, 2010 | 10:36 PM
SpiltTransFluid's Avatar
Car: '84 sport coupe
Engine: 355 .030 over 202 heads cam from RV
Axle/Gears: Idk, re is out of 93-97 V8
Crack open the cluster too. The needle might not be oriented property on its pin so you might try taking it off and setting again
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Prodigious
Oct 4, 2015 11:20 PM
Bstrang6
Sep 8, 2015 04:29 PM
ChevyZ71
Aug 13, 2015 07:30 AM
