dash swap help!
Old Oct 18, 2010 | 10:33 AM
SpiltTransFluid's Avatar
Car: '84 sport coupe
Engine: 355 .030 over 202 heads cam from RV
Axle/Gears: Idk, re is out of 93-97 V8
dash swap help!
Hi everyone, new to the forum here. I could really use some technical assistance with a dash swap that I performed. I have an 84 sport coupe originally a v6, now has a 350. I took the old v6 gauge cluster out and swapped it for one that came out of an 89 rs with a 305. So far the speedo works because they were both cable drive and I believe that the fuel gauge works. I know I can get the other gauges to work but I'm stumped on getting the tach to work. I had a sunpro aftermarket tach wired in and functional. My question is, can I just tap the green wire coming from my hei tach terminal into an open spot in the gauge harness to get the in dash tach to work? Thanks hope to hear back
Jorlain
Aug 24, 2022 05:11 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Vintageracer
Aug 11, 2015 08:13 PM
