Shifter fitment 4th Gen console
Old Oct 27, 2010 | 04:33 PM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Axle/Gears: 3.27 9-Bolt
I've been crusing through the threads on the 4th gen console install and was wondering if ayone got the 3rd gen shifter working with the automatic shift plate on the 4th gen console?
From what I can tell most people are using a manual or other auto boot??
I'd really like to use that 4th gen shift plate if anyone knows what needs tweaked
Old Oct 28, 2010 | 09:23 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Shifter fitment 4th Gen console
i was going to go this route, but i took the easy way out; i got a manual console
you can try to modify where the shifter mounts to the car; i think others have used the 4th gen shifter as well
Old Oct 28, 2010 | 12:23 PM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
I looked at a 4th shifter in the yard and they looked almost the same in height, if anything the tunnel is recessed a little bit.
Old Oct 28, 2010 | 12:44 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Its been done.
Old Oct 28, 2010 | 12:48 PM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Originally Posted by FueledSoul
Its been done.
If you got a link for a thread on here that would be great...
Old Oct 28, 2010 | 12:58 PM
FueledSoul's Avatar
here is info on the swap. post #17
http://www.automotiveforums.com/vbul...=633513&page=2
Old Oct 30, 2010 | 09:08 PM
gpingu87's Avatar
Car: 86 trans am ws6
Engine: 02 ls1 swap in progress
Transmission: 4L60-E swapping with engine
i m 3/4 of the way through this mode, have the shifter moved and remounted and just need to get the shift cable and wirng done.It seems a bit daunting but only took me like hour and half to move the shifter.
Old Oct 31, 2010 | 07:55 AM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
So you beat down the floor? Did you go about an inch?
What do you mean get your cable done? It just needed pulled as much as possible according to the other thread?
Old Dec 9, 2010 | 09:14 PM
gpingu87's Avatar
srry long time no reply. What I ment by done was was to mount it onto the shifter. I beat down the floor a good inch and a half with a mini sledge. Here is a Photo of it in there nevermind the mess, car is always that way.
1992 Trans Am
May 10, 2023 07:19 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Casey Meyers
Mar 2, 2016 10:46 AM
cam-mike
Aug 24, 2015 07:23 AM
