Step-by-step removing center console
Old Nov 8, 2010 | 02:36 PM
91FormulaQC's Avatar
Car: 91 Formula WS6
Transmission: None !
Axle/Gears: unknown
Im debating if I should remove my center console before or after winter because the last time I attempted to remove it ( in my late 88 firebird ) chaos ensued so I'd like to know about a step-by step guide with bolts locations etc.
I tried search but it doesn't want to work on my ipod =
Old Nov 8, 2010 | 03:37 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: Step-by-step removing center console
Remove it like permenantly or are you trying to get to something? There isn't a lot holding it on just get a flashlight and search for fasteners.
Old Nov 8, 2010 | 04:29 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I can get the top part mostly off, but only enough to change the bulbs in there. I can ever get enough room to search around.
Old Nov 8, 2010 | 04:45 PM
Car: 91 Formula WS6
Axle/Gears: unknown
Well I am trying to remove the carpet, maybe I named the wrong part =/ Its the part with the shifter and the armrest that I want to remove so I can remove the carpet.
Old Nov 8, 2010 | 07:35 PM
Mr Froman's Avatar
yeah yeah, the center console. I know with my formula you take out the two 7mm screws under the lid and the two under the ash tray and the top part comes off
Old Nov 9, 2010 | 02:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
In a Camaro, the underdash panel on driver side needs to be removed as well.
Also on a Camaro, the top has to be removed BEFORE the bottom half can come out, as there is a 10mm bolt that holds the bottom to the floor under the center between the armrest and the shifter.
And on the Camaro, there are 1 or 2 7mm screws holding the bottom to the underside of the dash, I believe 1 on each side on the console.
Old Nov 9, 2010 | 02:36 PM
Car: 91 Formula WS6
Axle/Gears: unknown
Basically this is what I want to know how to remove. So I'm going to have to remove the console where the air temp controls and the radio are to do so ?
Attached Thumbnails Step-by-step removing center console-efd26481e20217d6b8effde1365875ae9bdf2898.jpg
Old Nov 9, 2010 | 03:04 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Yes. You can pop the radio bezel off and then there are some screws holding the HVAC controls down and two screws behind that holding the whole pod down.
Old Nov 10, 2010 | 06:13 AM
Car: 91 Formula WS6
Axle/Gears: unknown
Oh sweet, thanks !
What about the console with the shifter though, how many screws and where are they located ?
Old Nov 10, 2010 | 08:35 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
There should be two under the console lid.
Old Jul 22, 2017 | 11:57 AM
rgauder's Avatar
Car: 1987 Trans Am
What comes out first, the shifter console or the HVAC and radio pod? I've got my radio pod loose, but it is hitting the dash when I try to remove it.
Do you have to remove part of the dash, or does the floor shift console come out first allowing the radio pod to come out next?
Old Jul 22, 2017 | 01:22 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Center console is removed first.
Remove plastic cover over ebrake. Remove shift lever. Remove center console trim (2 7mm bolts rear, bolt under the metal ash tray).
Remove the 2 or 3 bolts holding the center console to the frame. Remove center console (have your ebrake as high as it'll go, helps).
Now you can remove the radio pod.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Night rider327
Sep 2, 2015 04:17 AM
DonW
Aug 24, 2015 08:24 PM
Firebird sweden
Aug 16, 2015 05:02 PM
