speedo cable
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
speedo cable
i cnt get the speedo cable to connect to the back of my gauges, can anyone give me a tip on how to do this? i cant get my hand around the back to help push it on the gauge cluster.
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
Re: speedo cable
there is no other way sad to say. also if u cant reach ur hand up there, find the cable where it enters your floor board and try and wiggle it into the latch, thats what i did with mine cause i got big hands. just trace the cable as far as you can and do that.
Re: speedo cable
It's usually fawned upon by creating multiple threads (cross-posting):
https://www.thirdgen.org/forums/tech...esnt-work.html
https://www.thirdgen.org/forums/v6/5...ml#post4744648
Seems you're getting covered via the first one already.
Good luck!
Good luck!
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
