'91 RS ignition switch spring problem
Old Nov 26, 2010 | 04:36 PM
lilhanner's Avatar
I have several problems in my steering column at the moment, probably stemming from the tilt being loose for an extended period of time. I am currently replacing my ignition cylinder, but also have a problem with the ignition switch. Can you offer me advice as to where the small spring/wire that the switch comes with is supposed to go?? I know that the end with the small crook gets mounted on a small bolt down by the turn signal switch.. but what is the rest of it supposed to do/be attached to? It's taken me a while to get all this stuff off, and i don't want to put it back together wrong. Thanks for any advice you can offer.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
djmarch
Aug 9, 2015 05:27 PM
