Radios.....
Old Nov 27, 2010 | 02:24 PM
vengetta82's Avatar
Car: 1982 Camaro Berlinetta
Engine: LG4
Transmission: One that shifts hella hard
Radios.....
anyone know of any good plug and play or simple adapter aftermarket radios? my original radio wont play cassettes minus the adapter for my ipod, and is stuck on a latio radio channel...
Old Nov 27, 2010 | 04:32 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Radios.....
I just bought a beautiful used radio out of a 99 Grand Am for $20. CD player and 7 band equalizer. Harness plugged right in, even the power connection.
Littlebit of filling and grinding to get it to fit in the hole.
Old Nov 28, 2010 | 06:18 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Radios.....
you're slightly limited on your plug and play options, as the 82 uses the old gm harness, but that can be fixed pretty easily with something like this:
http://cgi.ebay.com/GM-DELCO-RADIO-W...#ht_1520wt_702
as eseibel67 mentioned, other newer stock decks will do you pretty well with little work (usually have to trim the mounting ears). I'm using a 97 Grand Prix radio in mine
