1986 Trans AM Ignition Problem
Old Dec 20, 2010 | 06:02 PM
my1986transam's Avatar
Hi,
New to the forum and glad to find it! I have a 1986 Trans AM 5 speed. Ben having some trouble with the clutch engaging to start the engine. Sometimes it works perfect and then every now and then puch in the clutch, turn key and won't start until pump the clutch a time or two. Last time this happened when turned the key another time, something happened in the ignition switch. The key turned freely. The steering wheel does lock, put in the key, then push the little release button beneath the key to try and start and the key just moves freely n the ignition as if the ignition tumbler is not catching on anything inside the switch itself. I located another ignition at an auto parts store. But, someone mentioned that it may be a gear rach thing broken that sits behind the tumbler. Anyway have this happen to them and if so how to fix the ignition?
Old Jan 7, 2011 | 02:09 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: 1986 Trans AM Ignition Problem
Looks like you're not having much luck here...might want to repost this in the Tech/General Engine forum.
Old Jan 7, 2011 | 02:21 PM
Hi, I agree!
Thank you.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
