Problem removing center console
Old Jan 4, 2011 | 11:29 AM
J-money's Avatar
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
Okay I'm in the process of removing the center console to remove the carpet, but I am having trouble removing one of the 7mm screws under the arm rest compartment. The upper screw on the drivers side is not coming out, it turns but just wont come out. I think the threads are warped on it. Has anyone else had this issue or any advice on how to get this thing out without breaking anything? And the car is a 1992 RS camaro auto.
Old Jan 4, 2011 | 11:40 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Problem removing center console
i would try to see if you can get a small flat head screw driver underneath the head just to put a little upward force on the screw. sometimes the speed nuts and sheet metal holes round out and just spin like you're talking about.
Old Jan 4, 2011 | 12:35 PM
J-money's Avatar
ok I just tried that method with no luck. Theres not enough room to get anything else in there with the socket to get much force on it. I've even tried turning it with pliers while pulling up with no luck.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Firebird sweden
Aug 16, 2015 05:02 PM
TheJoeY88
Aug 13, 2015 06:51 PM
3rdgenparts
Aug 8, 2015 07:09 PM
