Door Squeaks
Old Jan 10, 2011 | 01:37 AM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Door Squeaks
This is driving me crazy, sometimes it does it sometimes it does not , mainly when its cold outside u can hear it coming from the passanger door around were all the lock mechanism is, were all the rods and stuff like that is, i have sprayed white lithium grease around all the moving parts but it still doing all the noises, i have adjusted the windows so they are really nice and solid in all possitions but i just cant figure out were these noises are coming from inside the door, the door itself outside has a small rubber bump stop that meets with the body when the door is shut maybe that is whats causing the squeaks since its rubber agains metal but i doubt it since it sounds more like a metal squeak. Ill give the little rubber piece and the place were it meets the body a shot of white grease and see if that solves the problem.
Old Jan 10, 2011 | 07:54 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: Door Squeaks
I've got one squeak that drives me NUTS - I thought it was my mirror coming loose, but after taking the door panel off and finding everything tight, I noticed that the weld between the door skin and door inner had broken right under where the mirror was, right at the corner. It drives me nuts, but until I go to paint the car, I'm not going to worry about it, as rewelding it will likely burn the paint on the outside.
Old Jan 10, 2011 | 07:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Door Squeaks
Maybe something in the link below, if you haven't seen it, will be helpful:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Jan 10, 2011 | 11:37 AM
DSGx's Avatar
Engine: 305 TBI L03
Re: Door Squeaks
JamesC
Yeah i have tried all of that but its something different, the passenger door does it more often and louder than the drivers side door, what its weird is that while the door is making the sounds i open the door and it goes away and the close it really hard and it remains quiet. Maybe Ill try what you say and put zipties were all the rods go into a hole wich all have a lot of play and rattle when going over hard bumps.
Now like i said its prolly something around the area were the locks are and since it only does it while the door is closed i think it must be a binding issue between all the rubber isulation meeting with the metal body cuz it only appears to start squeaking when its cold outside, i live in florida so not really cold but just a little cold like around 65 degrees outside and it will start to squeak like crazy , the passenger side more than drivers. I really want to get rid of the noises cuz im selling the car and i dont want it to comeback when someone is test driving the car they would think its freaking falling appart.
Old Jan 14, 2011 | 09:41 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Door Squeaks
If your car has ttops, there is a metal ramp above the rear vent in the door jamb. This allows the gap to remain constant with body twisting and such. Under that ramp is a small plastic spacer. Remove the spacer and reinstall the metal piece. Check to see if this helps. It might be a sign that the door hinges are starting to sag and putting too much pressure on that metal plate.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
