82 TransAm w/Manual Cluster to 89 Formula Elect. Cluster (SUCCES)
Old Feb 16, 2011 | 06:27 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
I have a 1982 TransAm with cable speedo none electric cluster. I am
swapping in an 1989 Formula electric speedo cluster. As we all know there
doesn't seem to be any guidance on this here or any other board/website.
You will also need to have a VSS speed sensor on your tranny AND
the 'yellow' box near the ECM from the electric cluster car. Instructions
for the VSS and yellow box wiring can be found here.
http://www.hioutput.com/tech/speedo.html
Not shown is where the green/black speedo wire from the yellow box
goes on the cluster... it goes to L14 'lower connector position 14'
This shows how i moved the wires 'from --> to'. 'U' is for upper and
'L' is for lower connector.
UPPER CONNECTOR 'black'
7 6 5 4 3 2 1
8 9 10 11 12 13 14
1. green/ Temp --> L5
2. pink/ fuel gauge --> U10
3. grey/ Instrument cluster lights --> Stays here
4. black / ground -->U2
5. cruise? NOT USED
6. cruise? NOT USED
7. cruise? NOT USED
8. cruise? NOT USED
9. light blue/ dir. left --> U7
10. NOT USED
11. NOT USED
12. dark blue/ dir. right --> U9
13. pink-black /(+12v, shift/ses) --> L9
14. yellow/check engine --> i did not use it
LOWER CONNECTOR 'white'
14 13 12 11 10 9 8
1 2 3 4 5 6 7
1. Light green/High-beam --> U8
2. Not used
3. Not used
4. blck/grnd(inst.cluster lights/fuel/temp) -->L2
5. blue/lite-blue choke --> L4
6. tan/white brake light --> U1
7. not used
8. Not used
9. Not used
10. black/ground (volts, oil, fasten seat) --> L12
11. tan / oil pressure --> L8
12. yellow/ Fasten seat belt light --> L13
13. Not used
14. white/ tach --> L1
Old Feb 17, 2011 | 10:07 AM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
Re: 82 TransAm w/Manual Cluster to 89 Formula Elect. Cluster (SUCCES)
all i can say is DUDE.... You're a lifesaver....
Old Mar 22, 2012 | 08:22 AM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
How did you switch around the wires, did you splice them or did you just take the pins out of the harness to the cluster and move them accordingly?
Old Mar 22, 2012 | 09:34 AM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
I carefully moved the pins. There is no need to splice.
Old Apr 2, 2012 | 06:54 AM
Engine: 357
Man this sounds like a pain, Whatever newer cluster rocks socks.
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
okfoz
Oct 13, 2015 02:19 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
