Firebird Manual Hatch Lock Swap
Old Feb 23, 2011 | 09:17 AM
dredre08's Avatar
Car: 1986 Trans Am/1988 Camaro Iroc-Z
Engine: 305 TPI/350 TPI
Ok guys, I have a 86 T/A with that P.O.S. motorized hatch lock, well since I have had the car I have never gotton that thing to work and my hatch DOESN'T lock..... well I'm using all my money to put this new motor (355 Stealth Ram) in my car so I don't have the money to buy a new or rebuilt motorized hatch lock.... so I found a manual lock out of a 84 f body on craigslist and my questions are can I put this in my 86 and do away with the motorized lock and if so i have a few questions about the swap???....
Is it a hard swap?
How Long Does it take?
What tools will be needed besides the basics?
Thanks......
DJ
Old Feb 23, 2011 | 01:51 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Firebird Manual Hatch Lock Swap
If you got a complete assembly, ought to be a straight swap. It'll need adjusted some to reduce squeeking that the motorized hatch removes automatically by pulling it tight.
The motorized units are not all that complicated - once you get it out you might actually be able to see what's wrong with it and correct it. Most of the time it's a simple issue and not that expensive to repair (if any expense). TDS sells repair parts and rebuild kits. It's ust that they are fragile and cannot be slammed. If you get it fixed and put it back in, some tips are 1) never let anyone else close your hatch, 2) always use the release switch and not the key, and 3) never apply anymore preesure to close it than what it needs to just catch and start the motor working.
Old Feb 23, 2011 | 02:16 PM
dredre08's Avatar
Do u know what the complete assembly consists of
Because I don't think I have it...... I just have what kinda looks like the motorized one but without motor and wires and what not......
Here's a link to exactly what it is I have
http://cgi.ebay.com/ebaymotors/ws/eB...9732&viewitem=
Is this all I need for the swap or am I missing something??
Old Feb 23, 2011 | 08:58 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
No, the 82-85 manual latches are not a direct swap. The later cars have a completely different bracket welded to the body.
Old Feb 23, 2011 | 09:21 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
X2 on the fix. I have found that emergency repair procedure for one that is not obviously broken (No cracked housing or jammed gear) is to HOSE it down with wd-40 and use a small paintbrush to clean it off. Others will have other brands of cleaner, but I find that I ALWAYS have a can of wd-40 around...
Old Feb 23, 2011 | 10:42 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
You can do the swap, but it is going to take some fab work to get it done. The easiest way to fix your problem is to manipulate the assembly until you can get your hatch to close properly and then leave it unplugged. The downside to that is that you will not be able to use the remote hatch release switch.
Old Feb 24, 2011 | 02:03 PM
MNformula350's Avatar
Exactly. All you need to do is get the Latch and Mounitng Bracket that is Spot Welded to the Body off of a 82-85 Car, and Weld it in place of the Exisitng.
All in all it took my buddy and I about a 1/2 hour total. 100% Glad I did it (did it in 04), and wish I would have done it sooner.
In the Future any 86-92 Car I get (want a 91-92 Vert) This WILL be done 1st Thing!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Randomtask2
Aug 13, 2015 01:57 AM
