Source for decent replacement interior panel clips?
Old Mar 1, 2011 | 11:08 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Does anyone have a source for decent replacement plastic clips like those used to hold the inner door panel on? The dorman ones are terrible! Half of the ones I tried to use snapped off when trying to push them into the holes. They're the correct size and shape, but they're too hard and brittle.
I re-used as many of the stock ones as I could but I'm still coming up about a dozen short.. Any ideas?
Old Mar 1, 2011 | 03:01 PM
*84TA's Avatar
Car: 84 Trans Am
Re: Source for decent replacement interior panel clips?
http://shop.northlandfasteners.com/
Old Mar 1, 2011 | 03:04 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I had same issue - it's because they sit on the shelf at autoparts store and the UV from the flourescent lights kills the plastic. I bough the only two packages they had, threw them in the trash, and next week bought the new ones they restocked - cost me double and had to wait a week, but solved the problem.
Old Mar 1, 2011 | 03:38 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
I could see that happening, who knows how long they sit on shelves. I did buy two packages at two different times thinking maybe I just got a bad one, but had the same results.
I just ordered some from the northland fasteners link, they list one specifically for the 82+ Camaro/Firebird that is supposedly different from the rest. They also had some other clips that I couldn't find anywhere for re-attaching the upper part of the A-pillar trim so I got those too, lots of good stuff there
Old Mar 1, 2011 | 04:57 PM
*84TA's Avatar
Car: 84 Trans Am
Glad you found them. I ordered lots of parts there when I was putting my car back together.
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
AkDrifted
Aug 17, 2015 07:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
