Removing Seat Brackets
Old Mar 1, 2011 | 02:02 PM
Willishxc's Avatar
Car: 1985 Iroc-z Camaro
Engine: 350 V8
I have a 1985 Camaro and just took my seats out but i wanta keep the brackets that connect to the floor/seat adjusters, how do i remove these if i can?? It's probably simple and im just mising it :x
Old Mar 1, 2011 | 02:56 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: Removing Seat Brackets
The sliders/adjusters are just bolted to the bottom of the seat..
If you're talking about the braces with the studs on them that are attached to the floor, those are welded. You'd have to use an air chisel or drill out the spot welds.
Old Mar 1, 2011 | 04:01 PM
Willishxc's Avatar
Engine: 350 V8
Ya i need the braces, i ordered new seats that came with sliders, the old sliders dont fit on them. The adapter brackets are $190 and i just dont have it now, so i was hoping it'd be easier then that, or i may see if theres someone around me that can make some themselves cheaper. Thanks though G-reg.
Old Mar 5, 2011 | 01:50 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
most of the time. the aftermarket seats. have the rails set the same width. but run a bit short about 1 and 1/2" short. you can make the adapter. to bolt op your facry GM seat rails to the New seats.
if your under 5'8" tall it works out. if taller you need to use 2 sets of pasngr side GM rails. to get the driver side to sit low enof to fit a taller driver.
i have a full post with photos to take a look. you will see what im talking about.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Genopsyde
Nov 11, 2015 10:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
