Digital Gauges in '85 Camaro
Old Mar 5, 2011 | 03:44 PM
albertrios's Avatar
Hello All!
I wasn't sure where to post this but I thought here would be good. I have an '85 Z28 with the original gauges in it, but the speedo is the only one that works. I bought a tach and one of those oil pressure, water temp, and voltage kits and installed them just so that I could monitor everything. I replaced the cluster with one I bought and the speedo was still the only one that worked, so I decided to redo everything.
I was looking to install a gauge panel from summit racing; http://www.summitracing.com/parts/CTH-101820011/
But I also wanted to add digital gauges.
My car has a 4bbl carb and 5spd tranny. All of my gauges are analog. Would I be able to use digital gauges? Like would the sending units be the same? Also, what about the turn signals?
Any help would be great!
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
Jk_Under
Aug 17, 2015 03:08 PM
tartagliaz28
Aug 15, 2015 10:59 AM
beachrodder
Aug 7, 2015 04:27 PM
