87 IROC Z28 speedometer confusion
Old Mar 4, 2011 | 06:31 PM
churritos567's Avatar
Car: 1987 Camaro Iroc-Z Z28
Engine: 305 FI
Transmission: 5Speed
Axle/Gears: Stock
i jsut got an 87 iroc 305 5speed and the speedometer wasnt working along with the tachometer that was reading the rpms way high
the speedometer
i put it on a chassis lift and i saw the speedometer cable and i saw a electric sensor where it was right next to and i dont see anywhere else the cable goes. what should i check first?
the tachometer.
when im at 3000 rpm(im just assuming by the sound) its reading 6500 rpms.
where should i look at? what cna i do to get these components working properly?
thanks
Old Mar 4, 2011 | 07:11 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: 87 IROC Z28 speedometer confusion
What does the redline read on the tach?Just asking casue you might have a v6 tach instead of a v8
Old Mar 5, 2011 | 03:25 PM
Engine: 305 FI
Axle/Gears: Stock
tach reads up to 7
Old Mar 5, 2011 | 04:17 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Its very common for tachs to read very high as they get older. I had go go througj 4 tachs before I found one that worked. I even put in a v8 tach hoping it would would be wrong for a v8 ( meaning v8 tachs read low in a v6 car) but it was actually perfectly good for a v8, so it read too low on my car
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
mustangman65_79
Aug 11, 2015 03:17 PM
