Replaced my gauge cluster today now I have a small problem
Old Mar 17, 2011 | 05:15 PM
irocz28_350's Avatar
Car: 1990 Camaro Irocz
Engine: 350ci
I replaced my gauge cluster in my '88 Iroc today. All the gauges work now except for my oil pressure but I believe its the sensor. The problem I am having is when I started the car after installing it the buzzer/bell, whatever you want to call it, that alerts you to your lights being on or key left in the ignition was still sounding off, never shut off. I did lower the steering column to replace the cluster not sure if that had something to do with it or not but possible. Any help would be greatly appreciated.
Old Mar 17, 2011 | 07:03 PM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
Re: Replaced my gauge cluster today now I have a small problem
yeah theres a buzzer piece near the ignition that if not installed properly will do that see if a local shop can give you the all data for like doing the tilt bolts and that will explain how to put it back right
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
