anyway to restore center armrest?
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i have a 82-84 trans am center armrest from a junk yard.
it started coming up in one corner. its not cracked its actually in great condition. but the foam inside was all wet n rotted
i was able to peel off the top cover and pull out the bad foam.
has anyone ever tried replacing the foam in side? im considering trying this stuff from home depot which is called amazingly enough "STUFF"
its expanding foam and i figure thats how GM got the foam in there to begin with by squirting it through a hole in the plastic underneath
any thoughts?
any thoughts?
Car: 89 RS convertible, 82 MSE Trans Am
Engine: 305-305
Re: anyway to restore center armrest?
expanding foam expands unevenly, and ive seen it blow out sheetrock whentoo much is put in, basically buy some stiff foam, pull the vynal up, cut foam, reapply. glue is a magic thing!
Axle/Gears: no idea
ok thank you for the suggestion. ill have to check out a fabric store or something like that
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Foam shops will have the kind you need, the expanding foam is mostly a hard foam and would crush anyways.
If you find a reputable shop, I'd just bring it in and see what they suggest. Otherwise a fabric place may have generic foam as well, but know that there's different densities as well.
Density
The quality of polyurethane is determined by the weight of 1 cubic foot of the foam. The weight of the foam is indicative of its density. The density level of the best quality foam will be between 1.8 and 3.2, though that rating may appear, for example, as #21 instead of 2.1. The better the foam quality, the longer it will last and spring back. For seat cushions, look for 2.5 or higher for the density rating.
Read more: Different Types of Upholstery Foam | eHow.com http://www.ehow.com/about_5475795_di...#ixzz1HCYn9v3L
Axle/Gears: no idea
thanks for the info. ill have to check out the local shop first before ordering online but im sure i can find something that will work.
thanks again
thanks again
