What is this piece?
Old Mar 22, 2011 | 09:02 PM
Apolo's Avatar
Car: Camaro 1987
Engine: V6 2.8l MPFI
What is this piece?
My door glass driver is loseen, a lot of movement, i found this 2 pieces, the piece in the red circle sems loosen, like broken in the center, the second picture, that piece was on the bottom of the door, what are these pieces called? and where it should be, on the glass?
thanks!
Old Mar 22, 2011 | 09:07 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Re: What is this piece?
i think that is what holds the window in place...look to the left of that piece on the window and it should b the same thing...a nut goes on that to hold it in place...
Old Mar 22, 2011 | 09:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I think factory used rivets on those, but a short nut/bolt ought to work to fix - I'd use a locknut if possible and don't tighten too tight or you'll break the glass.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
LC2 TECH
Oct 13, 2015 11:53 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
RS Reaper
Sep 27, 2015 07:04 PM
