one key 2 cars
Old Apr 13, 2011 | 06:04 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
one key 2 cars
I have a Camaro and a Firebird, I would like to use one set of keys for both cars, is this possible/practical?
how does one do this?
Old Apr 13, 2011 | 06:54 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: one key 2 cars
Hello C.M.Jones!!
Anything is possible, in your case there is no VATS to worry about, so get your locks rekeyed to one key!!
Now is this practical, for you, it probably makes sense, as you have your reasons for wanting to do this!!
(You can only drive one car at a time, so why would you need them keyed the same, )
Beware that if someone gets your "key", both cars are subject to easy theft, and not just one if keyed individually!!
A key or ten seconds with a screw driver, both cars are subject to easy theft as they are right now!!!
Old Apr 14, 2011 | 04:24 AM
Brock Lee's Avatar
Car: 1991 Firebird Formula
Re: one key 2 cars
If you see many period GM's in the junkyard, odds are eventually you will come across an ignition switch and door tumblers that match. While there are about a hundred different key combination's spanning the era, far fewer are actually used often. Maybe 40 or so get used with certain combination's being more popular than others.
Old Apr 14, 2011 | 08:48 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: one key 2 cars
You can take one of the ign cylinders out and take it with the other car key to a locksmith and they can rekey the lock cyl to work with the other key. Cost maybe $30.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
ZsTransAm
Aug 11, 2015 07:30 PM
Kaweh
Aug 9, 2015 02:54 PM
