rear hatch panel clip alternative found
Old Apr 14, 2011 | 10:22 AM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: 9 bolt, 3.45
Had trouble finding the square rear hatch panel retainer clips. Dealer said they had been discontinued and sold out (probably to hawks or something) and didnt want to order them online and have to wait a week. Then i thought of thses:
they are from home depot and to hold wire ties for running cable. They have a double stick backing and a hole in the center. All i did was slightly enlarge the hole with a drill, clean the area where i was to stick them, centered them up by eye and stuck them on. They seem to be holding on quite well. If they pull off overtime i figure to use the 3M trim tape on the back so they'll never move. Best of all it was $2.00 for a bag of ten
Old Apr 14, 2011 | 01:51 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: rear hatch panel clip alternative found
Hmmm............I bought some repro/aftermarket clips from Florida Auto Fastener
in Alta Fl. by mail. I paid $7 bucks for 10 of them shipped to my door.
Fit perfect.
BTW they are pn#370364886463
Sorry I don't have the phone # or e-mail addy..............
They are on e-bay
One thing tho............I but mine on the BACK side of the metal mount so when you
tightened the securing plastic screw they won't pull away from their mount and get
loose.
Old Apr 14, 2011 | 03:24 PM
my82roc's Avatar
Car: 89 Iroc Convertible
You can get those at most auto parts stores.Usually located in the "HELP" section
Old Apr 14, 2011 | 09:19 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
NOPE..............................The Dorman/HELP clips are discontinued.
Some stores may still have some !
BTW: The dorman clip pn is 700-986
The Dorman 3/8 panel screw is pn 700-985 (black only)
In case somebody needs the Dorman #s
I bought the gray screws I needed used from 3rdgenranch.
I tried to get the clips from Dorman/help last year and finally found them
on fleabay seller Florida Auto Fastener...............
Old Apr 14, 2011 | 11:56 PM
puma1552's Avatar
Just get the GM ones, they are like a dollar a piece.
Old Apr 15, 2011 | 12:28 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello GTFiero
Try your dealer again with part # 20370594 qty 10 per bag!!
Don't have the bill with the exact price, but they were $5.00 - $10.00 CDN!!
Discontinued at the dealer doesn't mean they aren't still available, the dealer just needs to do a little bit of searching!!
Old Apr 15, 2011 | 01:08 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Originally Posted by 87IROC-DAN61
Hello GTFiero
yeah thats the number the dealer had, said there was no more left, and he even contacted a restoration company for me (dunno which one) that he said buys a lot of GM old stock and they had none. But these clips are working great
Old Apr 15, 2011 | 03:18 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Looks good GTFiero,as long as they work for you,good job.
Old Sep 24, 2012 | 09:39 PM
mich2112's Avatar
Car: 1991 Z28
Engine: 350 L98
Axle/Gears: G92 - 3.23
I found the Dorman part number for just the receiver part...
http://qa.dormanproducts.com/p-11517-45836.aspx
Dorman 45836
Many places carry them.
Mike Jones
Old Oct 1, 2012 | 01:47 PM
Joecat's Avatar
Engine: 2.8L V6
Transmission: 7004r
I appreciate this tip, the parts stores in town have had no luck getting these bits, I've had better luck scrounging at the junk yard
Old Oct 1, 2012 | 04:51 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Dorman 45836
Mike Jones
I guess Dorman fixed their site, now there is no such part number. I guess they don't have them. I need exactly 1 clip; I have the bolt/screw. I might give the OP's suggestion a try even though I don't really like doing it. It's reversable so....
Old Oct 1, 2012 | 09:10 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
These guys still have them:
Fit perfect.
They are on e-bay
Old Oct 2, 2012 | 07:39 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Thanks, I'll see if I can find them.
Old Oct 2, 2012 | 10:24 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Here they are:
Clips: http://www.ebay.com/itm/6-pcs-82-92-...item4846acdef0
Screws: http://www.ebay.com/itm/6-pcs-82-92-...item564a0c4624
Again I will mention Dorman/help no longer stocks them.
Some stores may still have some old stock in their Help section.
NO local GM dealers in my area have them either.
Old Nov 29, 2012 | 04:03 PM
dlinger's Avatar
Car: 1984 Z28 HO
Originally Posted by sonjaab
Here they are:
Thanks for this info. I purchased both and received them in less than a week. They actually reimbursed me for some of the shipping since they shipped them together.
Old Nov 29, 2012 | 07:35 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Cool..................
Like i mentioned above:
Insert the white clip on the BACK side of the metal body hold mount.
That way the clip won't come loose of the mount when you tighten the screw.
Less squeeks and rattles from the plastic pieces too.
I also got a set of Help/Dorman chrome interior screws with washers and drilled
a few holes in the plastic to the body metal in key areas to tighten up the
interior side panels where they over lap each other.................
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
