Steering column help
Old Apr 15, 2011 | 06:19 PM
redcamaro1988's Avatar
Car: 1988 Chevy Camaro
Engine: 305 TBI
I have a 1989 Pontiac Firebird Formula that I just got and the steeering column needs replaced. How would I do that? I have never had to do that before and dont know what to do. Also the column I am looking at came out of a 1989 Firebird also with a vats key do I need to change my ignition cylinder as well? Thanks for all the help.
Old Apr 15, 2011 | 10:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Steering column help
On the VATS - you'll need to get a key cut that fits the new steering column key cylinder, but you'll need it to have the same resistance pellet in the new key as your original steering column key.
Old Apr 15, 2011 | 11:25 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
The vats has a small orange wire and small white wire with a black connector 10 inches down the column. Take an ohm meter and measure the pellet in the key and go to radio shack and get a resistor the same reading. Take the same meter you measured the pellet with so you know it will be right. Put each end of the metal resistor in the black connector and you never need a pellet key again. If you don't have a key call a dealer and give them the VIN and they will get the key number for it. There are 10 different resistor readings.
Old Apr 15, 2011 | 11:29 PM
abray1's Avatar
I almost forgot, If you change columns there is a black box that reads the key resistor value so it will need the same pellet value even if it is a different column. The new column will need a new key since it is a different column but the black box up in the dash that reads the pellet value will have to read the same value or it will shut off the fuel and spark.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
