Wiring Electric Seats
Old Apr 19, 2011 | 08:33 PM
mcguffey4's Avatar
Car: 1991 Chevy Camaro RS Convertible
Engine: 5.O/305
Transmission: Automatic
I recently bought a set of leather seat that are electric. the seat I took out of my Camaro were not electric I would go about wiring these seats in? Only the driver seat is electric.
Old Apr 19, 2011 | 09:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Wiring Electric Seats
Seats will have 2 wires, a power and a ground. Can ground the ground wire anywhere (I dilled a small hole into my seat belt retractor at the bottom of seat, and put a sheet metal screw into it.
Power wire - run under the carpet or under the door sill plate, up to the driver underdash. In the fuse panel, you'll find an empty slot marked BAT - crimp a standard 1/4inch male spade connector to the wire, and insert into that slot.
That way, the seat will have power even without the key (so you can set it back after a shorter person drives, before you put the key in).
Old Apr 22, 2011 | 10:29 AM
aqualordx93's Avatar
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
what if you have a power seat, but a manual seat track??
Old Apr 23, 2011 | 08:52 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
If you run your wire to the bat slot make sure you put an inline fuse 20 amp. That will save you a lot of trouble if the wire gets shorted to ground.
Old Apr 26, 2011 | 05:45 PM
mcguffey4's Avatar
Engine: 5.O/305
thanks helped a lot
Old Oct 3, 2011 | 11:03 PM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
So the tracks are different (power and manual seats??). When I bought my seat off a 98 Z28 for my 91, it came with the tracks.. and the holes seemed to line up (have not wired up the power seat so I haven't bolted them in all the way yet.. Stone
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
