1991 Firebird Rear Hatch
Old Apr 28, 2011 | 10:56 AM
mmcalea's Avatar
Hey,
So i opened my trunk to take out my t-tops after driving and now the motor isnt coming up, so i cant close my hatch, didnt have a meter on me and its not parked at home so i did some examinations anyway.
The metal unit isnt all the way up, cant tell if its all the way down but the tan coloured plastic has a bit of a gap to the top on the rungs.
I pressd the black switch and nothing happened, I also tried inside with the other switch.
After taking the plastic covering off I have noticed the relay is unusually warm, should this be the case? (Could explain why i've been having a few battery issues)
Also the rear boot light isnt on, is this all on the same system?
Anyone have any suggestions on how I can begin to diagnose the problem?
I intend to head back round with some testing stuff tomorrow.
Thanks,
Mike
Old Apr 28, 2011 | 05:36 PM
MT91Camaro's Avatar
Car: 1991 Camaro RS
Engine: ewww...the 3.1L
Transmission: Not sure. It shifts quite hard.
Axle/Gears: 3.23 8.75" 10 bolt
Re: 1991 Firebird Rear Hatch
Test your relay. Sounds like an energized coil where the switch is stuck open.
Old Apr 28, 2011 | 10:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There are two relays, one buried under the center console, the other in the rear behind the plastic. Both available at Advance auto - one called hatch extend relay, the other look up Horn Relay (this is the one under the console).
Do a about hatch nmotors and issues - there's about 100 threads on the hatch motor issues in the last 60 days.
Old Apr 29, 2011 | 01:20 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
The first relay might be in the dash -- remember, Firebirds had the hatch release switch located on the dash, not on the center console like Camaros.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
