Shifter Knob
Old May 14, 2011 | 08:43 AM
aqualordx93's Avatar
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
Shifter ****
I have a 1986 Iroc Z camaro. It has a Ball shifter ****, im re doing in the interior, i want to put a brand new shifter plate in that fits over the console cause mine is very shot.
Im wondering if a T handle like a trans am will fit on directly?
Or will a square one from a later camaro will fit?
File Type: jpg
Old May 14, 2011 | 09:15 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Shifter ****
yes but you need to swap the entire shifter assembly since the clip locations are different
Old May 14, 2011 | 09:18 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: Shifter ****
I have a T/A shifter **** of my Camaro, without switching the assembly, I don't use the clip and it stays on fine and works fine.
Old May 14, 2011 | 10:11 AM
Engine: V8 305 TPI
Re: Shifter ****
im guessing i should just go for it, wont be that expensive. see what happens.
im thinking about going for the Trans am shifter, handle grip is alot nicer i think.
any opinions?
Is changing the shifter assembly that complicated??
Old May 14, 2011 | 10:18 AM
Engine: L31 350
Re: Shifter ****
any opinions?
4 bolts and a clip holding the wires to the assembly.
Old May 14, 2011 | 10:21 AM
Engine: V8 305 TPI
Re: Shifter ****
that doesnt sound to hard, now i just need to find an assembly on Ebay, or do i just need the handle? guessing the assembly...
Old May 14, 2011 | 10:34 AM
Engine: L31 350
Re: Shifter ****
id get the entire assembly, junkyards would probably be cheaper. just take the torx to get the shifter plate screws out, take out the 4 bolts. i think they are 13mm, and take a flathead screw driver to pop the clips off then remove. easy as that!
Old May 14, 2011 | 10:38 AM
Engine: V8 305 TPI
Re: Shifter ****
awesome. thanks dude!!
Old May 14, 2011 | 10:51 AM
Engine: L31 350
Re: Shifter ****
unless someone else chimes in i would double check the bolt size on your first, i dont remember since its been about a year since iv done mine so i dont remember that size, its either a 12 or 13.
Old May 14, 2011 | 11:31 AM
Engine: V8 305 TPI
Re: Shifter ****
ok, ill make sure to double check.
Night rider327
Feb 25, 2016 09:50 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
