What is the best paint to use on panels??
Old May 23, 2011 | 04:10 PM
Andrew1320's Avatar
Car: 1990 Pontiac Firebird
Engine: V8,350,5.7 L.
Transmission: Automatic - 700r4
So I am getting ready to paint my interior panels black. What would be the best kind of paint to use?? I know I'm not going to use spray paint cause it comes out real tacky. I was thinking something like Vinyl Paint. Is that a good choice?? Or does anyone know the best paint to use??
Old May 23, 2011 | 05:03 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: What is the best paint to use on panels??
I've used two different kinds. First I tried using duplicolor vinyl and fabric paint and it did work good but I decided I wanted to give it another coat of paint on the panels so I used krylon fusion plastic paint and I must say that the krylon holds up quite well compared to the duplicolor and I can run my nail over it and it won't chip or anything. I also took acetone and scrubbed the panels good to make sure there wasn't any grease or armor all on the panels causing the paint to lift.
Old May 23, 2011 | 08:48 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I've heard SEM makes a good paint. Maybe research it? little pricey.
Old May 23, 2011 | 11:21 PM
Andrew1320's Avatar
Thanks for the advice. I am either gonna paint my panels black or do sheet metal in place of my panels. My cousin did that in his 89' Mustang and it looked SWEET! So I think I might do that.
Old May 24, 2011 | 07:57 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Krylon fusion has done me well in the past on plastic panels. SEM is the king of the hill, but may be a little more expensive and harder to find. A lot of plastic painting comes down to prep - gotta get those panels squeaky clean if you don't want issues
Old May 24, 2011 | 08:30 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I've thought about the spray on bedliner. the kind in the can has a fine texture to it very similar to a dashpad, and I would think it would look nice, and be very durable
anybody ever try that?
Old May 24, 2011 | 09:07 AM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Doubt it but sounds like an interesting idea. Is that stuff flexible?
Old May 24, 2011 | 09:21 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I used SEM Color Coat and it works well. Just make to to clean/degrease the panels first, and then use an adhesion promoter (I used Duplicolor).
Old May 24, 2011 | 09:59 AM
82tarecaro's Avatar
I used SEM - it worked really good. Just use the adhesion promoter like 80schild said. I painted an armrest 6 years ago for my daily driver with SEM, and it still looks good today. I changed the color also, and the old color never showed through.
Old May 24, 2011 | 03:34 PM
Andrew1320's Avatar
Thanks everybody! I might try the Krylon Fusion.
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
